Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrical Inspection & Testing Forum
Enquire about continuity testing
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="binky" data-source="post: 505446" data-attributes="member: 490"><p>the idea of the testing is to test the cabling / circuits, not any equipment connected to it. Sounds like you are testing wrong having re-read your post. Continuity is usally done Live and earth, connect live and earth at the board end, (put ends in a connector block) then take a reading at the end of the cct. I like to do N-E as well. readings of 6-10 Ohms is a fail for most ccts. </p></blockquote><p></p>
[QUOTE="binky, post: 505446, member: 490"] the idea of the testing is to test the cabling / circuits, not any equipment connected to it. Sounds like you are testing wrong having re-read your post. Continuity is usally done Live and earth, connect live and earth at the board end, (put ends in a connector block) then take a reading at the end of the cct. I like to do N-E as well. readings of 6-10 Ohms is a fail for most ccts. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
