Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Give us a tip !
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Tony S" data-source="post: 478068" data-attributes="member: 20864"><p>There’s also the machine operator that thinks they know how to run the machine better than the designer. I had one who no matter how many times he was told/warned insisted he knew better. Without telling anyone I put a monitoring section in the program, even the electricians didn’t notice 700 registers had suddenly vanished. I then waited. Sure enough I was called in to a meeting following a near miss incident (near miss, it was a near fatality), revenge was mine!</p><p></p><p>Normally though, as Deke said, the operator can often point you to the fault.</p></blockquote><p></p>
[QUOTE="Tony S, post: 478068, member: 20864"] There’s also the machine operator that thinks they know how to run the machine better than the designer. I had one who no matter how many times he was told/warned insisted he knew better. Without telling anyone I put a monitoring section in the program, even the electricians didn’t notice 700 registers had suddenly vanished. I then waited. Sure enough I was called in to a meeting following a near miss incident (near miss, it was a near fatality), revenge was mine! Normally though, as Deke said, the operator can often point you to the fault. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Give us a tip !
