Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Student & Learning Zone - City & Guilds
Glanding SWA
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="binky" data-source="post: 507748" data-attributes="member: 490"><p>it's the only way to correctly terminate the cable, otherwise you end up with spiky bits of wire that could pierce / damage the insulation of the conductors - if nit earthing, then the banjo / piranha nut is probably surplus to requirement, just pust the gland nut on. </p></blockquote><p></p>
[QUOTE="binky, post: 507748, member: 490"] it's the only way to correctly terminate the cable, otherwise you end up with spiky bits of wire that could pierce / damage the insulation of the conductors - if nit earthing, then the banjo / piranha nut is probably surplus to requirement, just pust the gland nut on. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Glanding SWA
