Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Green Renewable Energy Forum
Solar PV Forum
Inverter size question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="johnb2713" data-source="post: 545997" data-attributes="member: 35153"><p>Apologies for butting in here, limiting the export is easy on your Growatt Inverter. If you access the settings via the shineserver on your PC you will find:</p><p>[ATTACH=full]15550[/ATTACH]</p><p></p><p>Note towards the bottom 'Set Export Limit' in my case it's off but if for example the DNO said 3kW maximum export, set it to on and 3kw is 60% of your inverter capacity, set the limit to 60. You then have to put the key in to save, the key is the date in reverse order eg today is 20230605 press yes and the jobs done.</p></blockquote><p></p>
[QUOTE="johnb2713, post: 545997, member: 35153"] Apologies for butting in here, limiting the export is easy on your Growatt Inverter. If you access the settings via the shineserver on your PC you will find: [ATTACH type="full"]15550[/ATTACH] Note towards the bottom 'Set Export Limit' in my case it's off but if for example the DNO said 3kW maximum export, set it to on and 3kw is 60% of your inverter capacity, set the limit to 60. You then have to put the key in to save, the key is the date in reverse order eg today is 20230605 press yes and the jobs done. [/QUOTE]
Insert quotes…
Verification
Post reply
Solar PV Forum
