Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Level 3 help please
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Ardet R" data-source="post: 462474" data-attributes="member: 30040"><p>I am not sure what the <em>standard </em>service illumination is, however the service illumination is the light intensity after the light fitting has been used for a while and this is what I showed above, the use of the maintenance factor provides this value.</p><p></p><p>This is calculating the Lux for the room based on the fittings installed.</p><p></p><p>If this is not what you need then I am afraid I would be unable to provide more information.</p></blockquote><p></p>
[QUOTE="Ardet R, post: 462474, member: 30040"] I am not sure what the [I]standard [/I]service illumination is, however the service illumination is the light intensity after the light fitting has been used for a while and this is what I showed above, the use of the maintenance factor provides this value. This is calculating the Lux for the room based on the fittings installed. If this is not what you need then I am afraid I would be unable to provide more information. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Level 3 help please
