Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Automation, Cinema, Computers, Television Forum
Network Cable Tester
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="kerching" data-source="post: 301031" data-attributes="member: 11861"><p>That looks quite useful I'll have to have a investigate</p><p></p><p>I also have a Paladin Cable tester [cannot upload a link or an image for some reason, sorry. Google Paladin cable tester...it is the grey and orange unit] 'identifying weird connections/pinouts' RJ45-RS232 25 pin, 25pin to 9 pin etc</p><p></p><p>Red lights down the centre light up corresponding to the piouts as you scroll down with the white button</p><p></p><p>For fixed cables you would need to loop back the far end so it would be easier if the points were in pairs I suppose...never tried it for fixed cabling though as both transmit and receive are buit in to the same unit</p></blockquote><p></p>
[QUOTE="kerching, post: 301031, member: 11861"] That looks quite useful I'll have to have a investigate I also have a Paladin Cable tester [cannot upload a link or an image for some reason, sorry. Google Paladin cable tester...it is the grey and orange unit] 'identifying weird connections/pinouts' RJ45-RS232 25 pin, 25pin to 9 pin etc Red lights down the centre light up corresponding to the piouts as you scroll down with the white button For fixed cables you would need to loop back the far end so it would be easier if the points were in pairs I suppose...never tried it for fixed cabling though as both transmit and receive are buit in to the same unit [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
