Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Radial and RFC from 1 MCB
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ProDave" data-source="post: 492634" data-attributes="member: 6969"><p>You do seem to be getting odd advice from your electrician.</p><p></p><p>If you are going to replace the cables with 4mm, you might as well rewire it properly as a ring on 2.5.</p><p></p><p>What type of consumer unit? Does it have an RCD (or two)?</p><p></p><p>Older houses often were wired on radials, which is not necessarilly bad, but do need to be properly protected. If the whole house is like this, then it is probably a candidate for a full rewire, or at least a consumer unit swap to allow you enough circuits to have all the radial circuits on their own mcb with appropriate rated MCB e.g I would keep all three radial circuits, on 3 separate 16A mcb's.</p></blockquote><p></p>
[QUOTE="ProDave, post: 492634, member: 6969"] You do seem to be getting odd advice from your electrician. If you are going to replace the cables with 4mm, you might as well rewire it properly as a ring on 2.5. What type of consumer unit? Does it have an RCD (or two)? Older houses often were wired on radials, which is not necessarilly bad, but do need to be properly protected. If the whole house is like this, then it is probably a candidate for a full rewire, or at least a consumer unit swap to allow you enough circuits to have all the radial circuits on their own mcb with appropriate rated MCB e.g I would keep all three radial circuits, on 3 separate 16A mcb's. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
