Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Small metal Sw/Fuse needed
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Evans Electric" data-source="post: 490154" data-attributes="member: 1408"><p>My take on this is the gear fitted in a meter box OUTSIDE of the premises would continue to be plastic , as with the equipment fitted by the DNO &amp; metering companies .</p><p></p><p>Plastic cut-out , plastic 100A main switches, plastic meters . The only reason I fitted a metal sw/fuse was to make off the SWA . Had it been meter tails I'd have used the Scholmore Main switch shown above. </p></blockquote><p></p>
[QUOTE="Evans Electric, post: 490154, member: 1408"] My take on this is the gear fitted in a meter box OUTSIDE of the premises would continue to be plastic , as with the equipment fitted by the DNO & metering companies . Plastic cut-out , plastic 100A main switches, plastic meters . The only reason I fitted a metal sw/fuse was to make off the SWA . Had it been meter tails I'd have used the Scholmore Main switch shown above. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
