Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
WhiteGoods & Appliances Forum
Water Damage To Cookerhood?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="M107" data-source="post: 329800" data-attributes="member: 28"><p>As above I've had a couple of faults just as you describe, simple repair both times. One a board swap the other a new switch.</p><p></p><p>Neither due to moisture ingress by cleaning, as already said odds on landlord is after somebody else covering the cost.</p></blockquote><p></p>
[QUOTE="M107, post: 329800, member: 28"] As above I've had a couple of faults just as you describe, simple repair both times. One a board swap the other a new switch. Neither due to moisture ingress by cleaning, as already said odds on landlord is after somebody else covering the cost. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
