Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Which Countries use sleeving?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="revjames" data-source="post: 502448" data-attributes="member: 5256"><p>In NZ and Aus, the twin and earth (TPS as they call it) contains 3 insulated cores all of the same size. No need for sleeving, although if they used switchwires the same way as we did they would need to identify the switched live return for example. They don't generally use this method instead they run the feeds around the switches and take a switched live to each fitting.</p></blockquote><p></p>
[QUOTE="revjames, post: 502448, member: 5256"] In NZ and Aus, the twin and earth (TPS as they call it) contains 3 insulated cores all of the same size. No need for sleeving, although if they used switchwires the same way as we did they would need to identify the switched live return for example. They don't generally use this method instead they run the feeds around the switches and take a switched live to each fitting. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
