Around 20 of the TL80 HFD fittings available, used, between 12 and 18 months old, including tubes and diffusers, most were hung from jack chain so they have hooks attached but are easily removed if required. Some have had the end fittings that hold the diffuses on drilled for conduit fittings or sensors but these are easily replaced at CEF and just clip in.
These are around £80 from CEF and I'm looking for £35 a piece for them. Collection only, from Milton Keynes.
Also, V207 dimming sensors, each one will control up to 4 of the above fittings and can be programmed for time delays, power down routine etc, you'll need a programmer to change them from their default setting (or a friendly Tamlite rep with a programmer). These were £77 each from CEF. 6 available for £35 each. Can post these if you just want the sensors and no light fittings. Paypal / cash / bank transfer.
