- Dec 2, 2009
- 350
- 0
Evening chaps,
I'm stuck with making right after the plumber and spark...
They left the room stat screwed over the cable, just stripped the sheath off and didn't screw the stat back tightly. This leaves the cores showing
Room is all decorated now - typical. I tried the stat on a pattress but the stat is too small and doesn't sit right. I've seen this issue before but not a solution, any ideas?
I don't want to replaced the stats if I can avoid it and chasing is out of the question, as is drilling from the other side of the wall.
Many thanks.
Many thanks.
