DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Just Pondering About This Amd3 Malarky?
Blue Duck
So in the event of a live to earth (or phase to cpc if your that way inclined) fault the lids of an AMD3 consumer supply unit (yes i said it) are made of metal how the fork are you supposed to isolate the supply? Yes I know what RCD's are for but it's not unknown for them to fail! same applies to if there's an internal fire it's gonna get hot and sparky how you gonna isolate the supply if you have to use a tool or key to open the CSU (not cooker supply unit).
I think it would be better to have external isolators fitted and some kind of busbar connection for the tails in the CSU, something made with lugs and bolts like a traditional bus bar system?
lastly has anyone found a good metal clip for holding cables in plastic trunking?
I'm mearly Pondering and pontificating and looking for amusement while the baby sleeps on me!
p.s sorry for the 5ww speak I never understood what was wrong with fuse box!!! headbang
Link to comment
if the RCD is inside the board how does it trip if the phase incoming tail touch the cover (phase to earth)
good clips I think there are some made for the fire alarm guys that fit inside MT2 trunking.
Link to comment
To most people it's still a "fuse box" even if it doesn't have fuses in. Just as their Dyson vacuum cleaner is a "hoover"
I don't see your problem though, the switch dolly is plastic usually so as long as you don't touch the metal bits?
Not many "Amd 3" consumer units on sale yet are there? let alone metal cable clips for t&e (like the old buckle clips?)
Just how are we supposed to comply if the kit is not easily available?
I'm guessing there will still be a lot of plastic CU's fitted for some time yet......
Link to comment
I'm jus picking holes in things really but I am convinced this hasnt been thought about properly! :(
contactum AMD3 CSU's have locks! what if you loose the firkin key and have an internal L > E fault then you really are doomed :lol:
"scuse me luv where's your consumer supply unit?"
"you wot luv?"
:slap
Link to comment
Denmans have  Eaton  ( AKA  MEM)   metal consumer units  which would look OK in a factory but you wouldn't want it in your hallway .   Very industrial looking .   However its not our problem .................as with many things in our trade ..decisions are made & passed down to the rank & file to get on with .
I shall be fitting plastic boards on domestic until I'm dragged off screaming TBH
There are millions fitted and not bursting into flames .............even the old wooden ones don't burn .
Link to comment
I am struggling at the moment to find a metal CU to fit SBS daves compact RCBOs in....anybody got any pointers?
CGD do one....but there stuff is usually sh'ite
Eaton do one BUT it is equivalent in cost to the national debt of a small principality
Curses upon you LFB....why not address the cause of the fire instead of just sealing it in a metal box?
Or am I just being picky
Link to comment
Maybe that's the trick? All these hipster café's with their £3 cortardo's, galv is making a comeback! maybe some polished pyro will be the next big thing? then we won't have to worry about fireproof stuffing glands?
@pony this the stuff ?http://m.ebay.co.uk/itm/like/131495946184?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=m&rlsatarget=&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F710-134428-41853-0%252F2%253Fipn%253Dicep%2526icep_id%253D67%2526mtid%253D1673%2526kwid%253D1%2526crlp%253D50600204586_563391%2526icep_item_id%253D131495946184%2526itemid%253D131495946184%2526icep_meta_categ_id%253D11700%2526icep_etrs%253DN%2526icep_epid%253D-999%2526icep_ctlg%253D-999%2526icep_cond%253DNew%2526targetid%253D75951457506%2526rlsatarget%253D%2526rpc%253D0.14%2526rpc_upld_id%253D50036%2526device%253Dm%2526icep_msku_flag%253Dn%2526icep_cbt%253Dn%2526adtype%253Dpla%2526gclid%253DCjwKEAjwhbCrBRCO7-e7vuXqiT4SJAB2B5u7DQL1wB1DAqMkyoBVEbAk9TY0Jw8il3m4or8-wqPvfxoC_NPw_wcB%2526srcrot%253D710-134428-41853-0%2526rvr_id%253D840269009862&ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F710-134428-41853-0%2F2%3Fipn%3Dicep%26icep_id%3D67%26mtid%3D1673%26kwid%3D1%26crlp%3D50600204586_563391%26icep_item_id%3D131495946184%26itemid%3D131495946184%26icep_meta_categ_id%3D11700%26icep_etrs%3DN%26icep_epid%3D-999%26icep_ctlg%3D-999%26icep_cond%3DNew%26targetid%3D75951457506%26rlsatarget%3D%26rpc%3D0.14%26rpc_upld_id%3D50036%26device%3Dm%26icep_msku_flag%3Dn%26icep_cbt%3Dn%26adtype%3Dpla%26gclid%3DCjwKEAjwhbCrBRCO7-e7vuXqiT4SJAB2B5u7DQL1wB1DAqMkyoBVEbAk9TY0Jw8il3m4or8-wqPvfxoC_NPw_wcB%26srcrot%3D710-134428-41853-0%26rvr_id%3D840269009862&_mwBanner=1
this is cheaper ;)
http://m.clasohlson.com/uk/Builders%20Band/Pr310674000
Link to comment
And Prysmian do a clip,to fit on my nail gun....what is not to like about that?
Apart from the price...
Just shooting
Link to comment
I am picking up a couple of the new Wylex boards tommorow. The only 1 item they have out is a 16 way box so after the main switch 14 ways or 10 if made up as a duel rcd.
Link to comment
044_1104_AP01_STEEL_ADAPTABLE_BOX_large.
= :D
Also why external isolators would be good to free up 2 extra ways! :)
Link to comment
I've had a look at the contactum ones,,,, the MCBs are straight across the middle giving very little room for traditional RCBOs...
Thankfully I use SBS in that circumstance
Link to comment
That is the one I am thinking of using with SBS Compact RCBOs
Just waiting for a price from my suppliers
Link to comment
Archived
  • Create New...
