Clutha
- Feb 9, 2018
- 7
- 0
Greetings,
I have to lay this out in best typing as I'm not allowed to post pictures, yet.
A friend has a sick electric/hydraulic log splitter. I fixed a hydraulic fault some time ago but now the motor is seized.
I'm mechanical by trade with some electrical experience from my time at sea.
The motor is 230v, 13.2A, 50hz, P1 3.00kW, P2 2.35 kW, 2,800 RPM, S6 40%, Cos 0.37, IP 54, Isol. KI B, VDE 0530/11.72
All the above from motor ID plate.
The chopper was working away when the circuit breaker tripped, the owner saw smoke coming out of the plug/socket on the machine.
I dismantled this and the female connectors, (on the plug end) were burned badly. It's a German type F plug and I fitted a new one.
On trying to start the machine, nothing happened. I took the motor fan cover off and it's seized.
Today I measure resistance at the three wires coming from the motor, (all disconnected).
There is one wire lighter than the other two, I presume the 'common'.
I got 330 ohms between both heavier wires to the common.
0.003K ohms between both heavier wires.
All wires to motor casing zero ohms.
Motor is aluminium with cast iron ends.
So, what say ye?
So, what say ye?
