DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
G bizzle
Megger mft1553
G bizzle
Megger mft1553
Am i right in what im saying here
Ze
open main switch to db.
Remove main earth
Use red+green leads
high loop setting
Measure between cpc+line
Record results in ohms
PFC
Reconnect main cpc
Use red+green black leads
Test between cpc neutral line
Pfc setting
Record results in KA
Zs
Testing live circuits with rcd protection
Use red+green+black leads
Measure between cpc+neutral+line at end of circuit
No trip setting
Edited by G bizzle
Spelling
Share this post
Link to post
SLIPSHOD & SLAPDASH
I would use the terminal/cable names rather than lead colours. My Metrel uses black for line , blue for neutral & green earth. My new Fluke uses brown for line.
Most, but not all meters will record/test Pfc when testing Ze.  I also test for Psc  PFC is tested Line to Earth.
Share this post
Link to post
Risteard
Not correct.
PEFC is Prospective Earth Fault Current which is phase (or line if you want to be all 17th-Editiony) to Earth.
PSCC is Prospective Short-Circuit Current which is phase to neutral (or between phases in a polyphase installation).
PFC is Prospective Fault Current which is the greater of the PEFC and the PSCC.
Edited by Risteard
Share this post
Link to post
G bizzle
Yes i know this mate thankyou. To test this with a megger mft1553. I know its a live test with the main switch and mcb's in the open position.
Is it the pfc loop setting
Red+ green leads that you use for the measurement.
Regards
Share this post
Link to post
SLIPSHOD & SLAPDASH
11 hours ago, Risteard said:
Not correct.
quite right. I am getting to old with all the same things having the names changed. Bring back live, neutral & earth, nothing else  :coat
Share this post
Link to post
G bizzle
Guinness
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
