DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Rutts35
New CU
Rutts35
Fitting stand alone unit as requested. Find brand new CU had been fitted. Builder used his own sparks. No EIC, no test date. All factory neutrals finger tight. Plus no cpc in at least the down stairs lighting circuit. Plus a radial for a boiler fused spur in 2.5mm on a 40A breaker.
Notice the 'extra" earth bar.
Share this post
Link to post
kerching
Nice job!
Share this post
Link to post
Blue Duck
So the builder charges customer for the services of a spark but doesn't use one?
Share this post
Link to post
kerching
Well,if he did use a spark then he needs finding and dry reaming with every version of the regs since 1850, all amendments and guidance notes, then going for a swim with barrymore
Share this post
Link to post
Murdoch
OP - who asked you to fit the board you turned up with?
Share this post
Link to post
Rutts35
The house owner mate. Why?
The house owner had an extension built and the builder used his own sparks. He stated, at the time, that due to the extension a new CU was required. He then fitted the above leaving no spare ways. I was then asked to carry out works for them which required a two new circuits and hence another way which wasn't in the board. Due to the poor install I put both new circuits in my stand alone board rather than touch the existing board.
:slap
Shouldn't be laughing really, especially the Barrymore bit!!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
