Hi Guys
Just seeing if anyone can help out an issue I have on a job. The plumbers have installed two wet underfloor heating zones which both have there own thermostats. At the manifold they have fitted two motorized valves, one for the central heating in the house and the other to cover the two underfloor heating. The customers boiler is wired into a basic time clock and he controls the heat via the boiler's controls. I've been supplied a Heatmiser UH4 so for his central heating I have wired the time clock into the first stat and wired the brown and blue cable from the first motorized valve into the actuator L & N. This works fine for how the customer would like it however I'm having trouble working out how to wire the other motorized valve. As there's two zones with two stats I'm not sure how I'm to wire the one motorized value across two zones, is it possible? I've tried to attach a couple pictures of the instillation that I've took, hope you can make them out, any help would be much appreciated. Cheers.
https://www.google.co.uk/search?tbs=sbi:AMhZZivU8nymdcYBdbrvLpV4SKt5QZ0jSYIOKBMJ9PsSCUIGUxZZ-1pKgCQcYrlkaV37aKeA9pU38Edos0pwjIxjGZmzu27iGk4VjecDI9YRubH-mh1DByQ-wgembXOsUKIitrBkVCymSuT1RE-bUFo9OMTtRhKGJT9tGzBTHW472BCcICCE9kp0f-4yylF5Ea9bHkp-wpwU311azsn9eRkEmj4HmC63t8BJk7ZiAdfuvF0-3nRa18xAUZexgTnyi2MoGsaajjcNL49bbsbwc1ezBY7teGYdZ747uo09Yd2F2HMvobPM6R1i_1vLg6zgRmQM1j0Xnuh-Q&hl=en-GB
https://www.google.co.uk/search?tbs=sbi:AMhZZis3VngU7qJY5pF5kovBFpf89kn7YJSGpf1Fj-qK_1tnSxvGBTtsZSG5rnADzxBRYuMZK0-XgFhMAKEL-xPOvaa2Ih9B8uYkQvNYyzbYfHoif2xzDIPSm0lUCdeEhvtOkCmn9oFO5BKlXIfrJnDLP5Fvx50qZ3ihn_12eBFvH65jGsEE0po31GZ7NtWgH9lQnBVw2S2O178iUEFBmyXwVOtoRulWYMu9YAv603t442woHWCxn3bWbTkYs-zoSy9D-JZv7axByHGQNCLTkKL34rglb9Z-Onb8PJSTGh4J4oLEmxuq_1E3naFu2V2xQ9Gtr97uaIaxUyi&hl=en-GB
