DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Earthing change
OldPeeBee
I am about to change a DB in a stable block to TT; as at the moment it has an exported earth from the main house (TNC-S). The DB is a split load board with a 30mA RCD for the power side; main switch is standard 100A. Should I change the main switch to a 100mA RCD or utilise the existing RCD as a main switch/RCD for all circuits?
Link to comment
install a dual split (which will be cheaper than split load with TD main switch). every circuit must be RCD'd, and if you install a 100mA main switch, you may not comply with the 30mA req'd for certain circuits, and you wont have discrimination
Link to comment
Trying not to replace the board as it is only 3 years old. Just need to cover the 4 lighting circuits which are on the non RCD side.
Andyc - TD main switch??
Link to comment
RCBOs?
Link to comment
TD: Time Delay (as in rcd with a time delay to satisfy discrimination with other RCD's.
Not sure all RCBO's will disconnect both Line and Neutral.
Link to comment
you can mod a split load to make a dual split. providing you have 2 spare ways
Link to comment
Is there any reason why I can't cover the whole board with one 30mA RCD; with or without utilising the main switch.
yes - nuisance tripping!
Link to comment
Archived
  • Create New...
