DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
outside wiring
bernard longden-thur
Question
Hi, i have an outside job for a woman, she wants power in her garage. The garage is about 15M from the house, but without an excavation digger it is going to be impossible to dig a hole as i have tried and a cantenery wire will look out of place. Is there another alternative that can be used, i have not done this type of job for years.
Link to comment
18 answers to this question
For mechanical protection, incase some one decided to hit it with something sharp and metal. etc
Link to comment
catenary wire with armoured attached might be the only answer, cable must be armoured,
why?
Can anyone confirm this? I can think of a number of places wire is taken to outbuildings in standard T&E supported overhead.
Link to comment
Is there no alternative discreet cable run that you could take using SWA?
Obviously you will need to think about likelyhood of cable being damaged, volt drop etc..
Or howabout getting this woman to agree on a local driveway company to quote on diggin trench and then making good once you,ve layed cable. They might agree on it if short of work or in between jobs.
You need to tell customer that there is a certain amount of electrickery you can do, but invisible cabling or 3G power to open her garage doors hasnt been done yet.
Link to comment
Tw/e was always used on catenary wire in the old days. When I first started out we did quite a few to supply buildings in schools. But personally myself I always use swa that way it should outlast the life of the building.
Batty
Link to comment
I suppose it all depends on the location, doesn't T+E react badly to exterior conditions and become brittle over time?
Link to comment
Over many many years the PVC degrades with UV light - as with almost all plastics.
Link to comment
Whilst the outer sheath of SWA is ............ Bugger! ROTFWL
Link to comment
true but it is a tougher plastic
Link to comment
absolutely no reason why t&e couldn't be used if its installed to a correct reference method and reasonably not expected to be damaged
i.e flat clipped to a wall
Link to comment
i wouldnt like T&E on a cat line. H07RNF or similar would be a better alternative
Link to comment
Concur..
solid conductors over a moving support wire structure???
not the best IMHO:(
T&E can be fixed to solid structures externally...
providing suitable consideration to any external influences are taken into account.
UV from sunlight & mechanical damage are two big ones!
personally I would Never use an unprotected PVC T&E on a long external run.
ok for a short drop to an accessory e.g. light / PIR. :|;)
Link to comment
catenary wire with armoured attached might be the only answer, cable must be armoured, you cannot use twin and earth conduit cable or any other form of cable including rubber :^O
Link to comment
Concur..
not the best IMHO:(
Applaud Smiley
Link to comment
Link to comment
Nice option Andy.....Applaud SmileyApplaud Smiley
Do you get the car free with the cable enclosure?????Blushing
Link to comment
no, you get the front half though!
Link to comment
Bast***s!
they make you buy a second one to get the back half!!!X(:_|:_|:(
Link to comment
Archived
  • Create New...
