DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Main RCD???
NozSpark
Question
Lets say you have been asked to replace a shower and the CU whilst reasonable new has no RCD protection,, you recommend RCD protection and they agree to it,
they will not go as far as a CU change and RCBOs would be overly expensive............ they are however happy for it to go in the tails and accept the problems that would arise in the event of a fault...
I know that this is not strictly to the regs, but would you do it or not???
Surely any RCD is better than none???
Link to comment
20 answers to this question
rcbo are expensive i pay
Link to comment
that is cheap. are they crap
didnt want to waste
Link to comment
didnt want to waste
Link to comment
I would do as Ianmacd says , put the RCD on the shower , you have done your bit as safe as pos. You have made the customer aware , each set of regs are not retrospective, if they don't want it ,then as I keep saying, we are not the Electric Police.
Its like a car mechanic I suppose, who tells you your car has four bald tyres and dodgey brakes. He can do no more, its now up to you, get the credit card out or ignore his professional advice .
Link to comment
Concur with Deke & ianApplaud Smiley:D
Divert the old shower cable out of the CU into a new standalone RCD...
run cable from CU MCB into this new RCD.
The circuit YOU are working on is compliant...
But you have NO obligation to have to amend any other circuits you have not worked on!!
I did a replacement shower like this a few months back...
just RCD the circuit..
advise the customer "in writing" and note on CERT.
no problem;)
Link to comment
yes. often. sometimes its the only way
Link to comment
I would not but I am busy so can pick and choose work to a certain extent. Just remember if things do go wrong it will be you that they blame.
Batty
Link to comment
Noz - would have made a good poll!
Batty - what could go wrong?
Link to comment
When the RCD trips out at 10 o'clock in the evening and they are left in darkness.
Link to comment
Then they work out which circuit is causing it, leave the MCB off and no bother?
RCBO's for them with a minuscule of common sense?
Link to comment
No good if its a neutral to earth fault though.
Link to comment
leaving the MCB off will have no effect on a N-E fault. or even a L-E fault depending where on the circuit it is. using DP MCB's would be the only way to fully isolate a circuit
Link to comment
I would have thought that if they are advised of the risks and accept them; then that should be OK..
Link to comment
Why not just put the shower circuit on an RCD?
Would not comply with 17th ie other circuits in bathroom but if I had to do it I would do that rather than having one Rcd for whole house.
Link to comment
Archived
  • Create New...
