DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
First TT
MalcyB
Hi all
I did my first TT today. lowest reading 255ohms!! I'm going to use the bigger rod tomorrow. Apart from the dry weather what else could be the problem?
Malc
Link to comment
i have just done a TT system... i got 600 ohm... so i installed another one as well and got it doen to 90ohms... ( also have a quick wee on it)!
As long as you have a under 200 ohm's and its all on a RCD ... happy days.
Link to comment
All depends what ground is made of. In my area there is chalk which is a poor conductor. There is clay in places which is a good conductor as its very wet. What is ground made of where rod is inserted.
Batty
Link to comment
Put a second rod in a full rods distance from the first.
Or use the 5/8th rods with screw connector, drive in the first one screw on the second & drive on in.
Use crimp lugs to connect mec to the clamps.
Link to comment
Day 2
Put a bigger rod in, came down to 230ohms, put a second standard rod in a metre from the larger one , came down to 163ohms.
The area is on a limestone hill, I bought a 1000mm sds bit and drilled the ground the bottom bit came out dirty white!! I take it I keep sticking rods in?
Malc
Link to comment
It's upto you but I'd go with the 163ohms
Link to comment
163 is acceptable. unless you feel like its going to dry out and go over that.
Link to comment
I remember my first TT.
All them Motorbikes, all that beer.
:Y:Y:Y:YGuiness DrinkGuiness DrinkGuiness Drink:Y:Y:Y
Link to comment
Archived
  • Create New...
