DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
help
spenceriles
Question
ive been thrown this question by my firm to find out but im stumped
how would you carry out a systematic fault diagnosis of a reported faultly circuit
can anyone help
many thanks if you can
Link to comment
3 answers to this question
A bit ambiguous ( thats to impress ExBDC) there Spencer. They should specify what circuit and whats wrong TBH
Deke
Link to comment
how would you carry out a systematic fault diagnosis of a reported faulty circuit
can anyone help
I assume this is basically asking..
"what is a logical approach to investigating any reported fault"
I would suggest a procedure something along these sort of lines:-
A/ Understand the customers complaint:-
Speak to the customer to identify the fault symptoms.
  • Where is the physical location of the non-operational item(s)?
  • What circuits are they supplied from?
  • Where is the distribution board for the faulty circuits(s)?
  • Has there been any recent alterations / maintenance work?
  • How old is the circuit, (i.e. how long has it previously been working for)?
B/ Locate the circuits / distribution boards / accessories
Check for the obvious,
  • Are all fuses intact?
  • Are all MCB's, RCD's correctly set 'ON'?
  • Are all switches isolators on?
  • Any timer switches correctly on?
C/ Investigate circuit composition / layout / connections
Undertake safe isolation of circuit.
  • Carry out 'dead' tests on circuit.
  • Verify continuity of CPC, Line & Neutral!
  • Verify Insulation resistance of circuit.
  • Verify continuity of all switches, (as well as physically On is electrical continuity sound)?
  • Test continuity through accessory leads
etc...
Link to comment
Archived
  • Create New...
