Ok, let's see whose maths is still there because mine has left the building!
I have, I think, 3ph power being superimposed onto an analogue signal line.
I was expecting to see 50Hz on the scope traces, that is individual interference from each phase.
As they are all synchronised, then I would have expected them to add to the same 50Hz signal and even though phase shifted, the fundamental frequency is the same.
Ive taken a time / voltage trace of the noise, then run it through an FFT to get the frequency components, hence I was expecting 50Hz!
I'm not getting it!
Now I'm still working on the maths & graphs & the possibilities.
However, as we have 3 off 50Hz signals out of phase by 120 deg or 2(Pi)/3 could or would these superimpose a higher fundamental frequency?
If so what would that frequency be?
I don't think it would be 150Hz, because of the phase shift.
My maths head is really gone now!
It's been so long since I've had to look at stuff like this.
Forget about harmonics from loads for a minute, let's just think about the fundamental basic 50 Hz 3ph supply with each phase shifted by 120 deg.
Take it that the load is balanced & the pf is unity, just for now.
Looking for ideas now as I'm not getting what I expected!
I'm not getting it!
