Question 1: is it acceptable to modify the meter mouting board or does it belong to DNO? i need to trim off 35mm to allow a new consumer unit to fit, an alernative postion isnt really feasable, because it would suffer impact damage.
Question 2: When running main equipotential bonding on outside of building is it ok to go through the wall sharing the hole with other services e.g. supply cable, gas pipe or waste water outlet?
regards
Mouse
regards
Mouse
