Advice for another DIY Solar Install.
May 10, 2023
12
Hull, uk
Hello lads! I'm new to this forum. Does anyone can help to choose right breakers for system and make sure they in right spot? I'm doing self install and Got DNO approval on G99.
I got solax x1 3.0 string I beleave and solax x1 retrofit 3.7kw ac coupled with battery.
Thank you
Split from hi-jacked thread
Thank you
What are the maximum amps outputted from the inverters?
First pic is for ac charger. Also I got 4kw battery with it. It's connected and it's running without any issue at moment. I'm just not 100% sure what breakers, rcd's or rcbo's is required.
Now it's connected trough B20 breaker
Hello again. After modernisation here is my DIY system:
6 x solis 405w panels
Solax x1 3.0TD string inverter
Solax x1 retrofit 3.7kw + 4kwh solax battery
All up and running with no any issue.
Have g99 approval, now needs someone to commissioned it. MCS not really bother.
Is there anyone can help? I'm from Hull, East Yorkshire .
Thanks in advance
It’s a new circuit so an EIC, earthing and bonding and Part P apply
Hope it’s not connected to a shared RCD
Have you got blank forms?
I still need some advice to get correct protection. At moment Inverters run on 20A breakers. They connected to DNO earth. I got earth spike and think to get connected panels to it(lightning protect).
Also, why RCD? Why not RCBO?
