Axiom MCB problems
big chaz
Jan 11, 2022
Hi, I have a new plasma cutter and it powers on fine, but as soon as I pull the trigger the breaker trips instantly. B32 breaker, 6mm t+e and 32a socket. Im thinking the breaker needs changing, and having checked the plasma manual it recommends D32. Problem is, i cant find any D type or even C type axiom MCBs online anywhere. Does anybody know what other brands of MCB (if any) will fit an axiom consumer unit? Thanks
its not a simple case of changing the MCB type, youll need to verify the circuit is capable of working safely with it, and with D type, chances are not. you also cant mix manufacturers MCBs
