help with adding a circuit?
your all spending far too much on cable and should be sacked.
all is needed is a single cable for supply you can get the newtral from the copper pipe nearest the shower i.e under the bath or airing cupboard using a crocodile clip. or if your feeling like a super spark use an earth clamp
your all spending far too much on cable and should be sacked.all is needed is a single cable for supply you can get the newtral from the copper pipe nearest the shower i.e under the bath or airing cupboard using a crocodile clip. or if your feeling like a super spark use an earth clamp
As already stated in post #18 you mean? - this is the only method we have consensus on, can we agree that this is the future standard for 12kW showers then?
I'll ask Seamus if he has any rubber insulated singles - I assume size and colour aren't important?
