cruelty
hi,
system has 2xCH & 1xHW Zones
system also has solid fuel back boiler
system has 2x CH Motorized valves
Garage = Oil Boiler & Pump (No over-run)
Hotpress = Cylinder, 2 motorized valves, CH circulating pump & Back boiler pump, cylinder stat, back boiler stat
so there is 3 zone time clock (2x CH & 1xHW)
2 CH room stats
what i need to happen:
CH1 turned on = fire Boiler + pump(garage) & Circulating pump (hotpress) & open corresponding "MV"
CH2 turned on = fire Boiler + pump(garage) & Circulating pump (hotpress)& open corresponding "MV"
HW turned on = fire Boiler + pump(garage)
Back boiler when lit = opens both CH motorized valves & fires Circulating pump(hotpress)
I need a wiring diagram for this system
if you could be so kind to help me out i would be forever grateful
2 CH room stats
