Hi, I've been asked to fit a replacement oven with separate hob. The old oven and hob are electrically attached to each other and then wired in to the cable that comes out of the cooker switch on the tiles above the work top (no cooker point behind oven).
The CU is an old one and there are no RDCs on it. The owner is keen not to rewire. So I thought I'd fit RCD protected sockets or fused spurs.
This will be ok for the hob (the new hob plugs in seperately, normal 13 amp plug) but what about the cooker? I like to know if any of you have come accross this before and what you did please. Does such a thing exist as an RCD protected cooker switch?
thanks.
thanks.
