Recommendations for reliable LED floodlights
Dec 8, 2016
2,123
493
Blackpool
I'm looking for recommendations for reliable LED floodlights to use as feature lighting, that is illuminating walls. I think around 50 watts will be suitable.
Access for maintenance is difficult and expensive so reliability is the over-riding requirement, much more important than initial cost.
Additionally this is a near coastal location with a salty atmosphere. (Powder coated alloy fittings last no time at all).
Fitzgerald were the only light fitting I would use on any project. Between us we won two Lighting Industry awards. I got on very well with Peter Fitzgerald, his son Tim and the Sales  director Tony Stuchberry. Alas due to personal circumstances and health issue we lost touch. I wasn't aware they had teamed up with powerlite. If the new regime has the same quality products and customer service then you won't go far wrong
I know we should buy British but personally would avoid anything made by a certain firm in Staffs. On the subject of LED floods, I have fitted several NVR (from neweys) of various wattages on and around the Port where I work with very little in the way of failures.
Apart from Fitzgerald, I've always found Crompton LED lamps to be good, Kosnic LED gear trays, and KSR LED battens are good now they've sorted out the hest spec - they originally rated things for 30degC, so a load of lights I fitted in a school overheated one summer.
