Regulations concerning meter tails
you can get multistrand meter tails that are far more flexible - i forget the name they call them, superflex or something like that.
I used some for th first time recently
brilliiant
far easier BUT you have to retightennthem a few times
trirated....I've used trirated up to 300mm and bi rated above that. This stuff lies half way between standard tails and tri rated I reckon
Shouldn't fine stranded cores be used with ferrules in tunnel terminals?
(Just asking, I don't claim to know the rules here).
Ill try and find a bit to strip,and post a pic later
its not that fine really
this was in rising clamp terminals, torqued up, had a brew, re torqued, left it half an hour, retorqued, THEN I was happy with it
Tri-rated
tri rated cant be used as meter tails because its only single insulated, not insulated & sheathed, so would need to be fitted in conduit etc
the more flexible version isnt finely stranded either, it has more strands than the usual but they are still reasonable thick. although i have seen some that are finely strande like tri, but are correctly insulated and suitable
Perhaps flexible are being sold as tri rated?
https://www.google.co.uk/search?
