Shrill noise from central heating
Tom78
Apr 7, 2018
7
I am getting a phone like noise emitting from the Cupboard where my Vailliant EcoTec boiler is installed.
The boiler has been checked by Vailliant and nothing was found.
The noise is intermittent.
The Condenstat has been changed due to horrible noise and while that noise was cured the phone like noise still occurs.
I Have a Digistat 1RF Thermostat working with a DigistatSCR.
Alongside the SCR is a Honeywell ST9400C Programmer'
Close to the Cylinder is a small unit labelled as V4073A1039 Do not know what this is.
Any help regarding the reason for the noise would be appreciated
Does this happen when you are switching the heating on or off? Do you have a pump on the pipe work? It could be air passing through the pump causing it to run dry.
How good are you at following instruction?
Sharpend
Thanks, i dont follow instructions very well, nearly 80. The most recent suggestion from both yourself and Evans Electrical  re sticking valve looks promising.
would it be a job for an electrican or a plumber?
The only visible gauge on the boiler, Has a display showing two symbols, and I assume is a temperature reading.
on the right is a sliding scale with bar at the top which I am assuming is the water pressure. The scale has an upper and lower points and is currently near the upper level but in between the two limits.
Yes there is.
A PRO 135430 Condensate pump which was replaced recently due to sounding it was going to fall a part, and is quite now and  a IntaKlean IKMF22 or IKMF28.
None of this appears to be effecting the performance of the system just making this noise.  Worried it maybe dangerous.
Yes exactly that.
cannot load pic max size allowed is smaller than I can create.
Shrill noises can be instigated by kettling, loss of water or air is stuck inside your system. If it is trapped air, you can simply fix this by bleeding your radiators. ... When they bleed your radiators, they'll also find out what caused air to become stuck in the boiler and accomplish the suitable repairs.
But before doing this, you might want to have a service specialist come out to inspect your system, who can physically hear the sound that your radiators are making and examine your system.
