This months PE Mag, I despair, really I do
Oct 22, 2010
14,507
1,077
Home for the terminally bewildered, one step ahead
So in the Black Musueum/Ill informed contributors section
there is a picture of a Trimline fitting.....there must have been millions of these fitted. The internal reflector is a aluminium foil pressing. The contributor ( and I use the word contributor in the loosest of runny dog turds sort of way) thinks it is actually a pie tin! And so does 'an inspector says'! I feel he would be better employed as a Proctologist.
if either of the cretins knew their job OR was blessed with a pair of eyes ( even one eye would do ) they would have seen the words Max 60W /100W depending on whether it was the 10" or 12" version
With this in mind how much scare mongering has this ill informed twonk forced upon his clients
just...well, just!
I call them pie dishes, well aware they are no good for making pies.  ;
But its good to know that If you found one damaged you could go to a local convenience and get a Fray Bentos steak and kidney, chuck the contents, (for God's sake don't eat it) and Jobs a gooden!
Seriously!?
I dunno what's going on!?
Same issue  ...what the hell is this about    :C
If that is meant to be an example of how a competent person does the job then it's an epic fail.
Why screw a row of JB's to the wall when there is nothing wrong with loop at switch or loop at light? and if you must do it with a central junction box, use ONE junction bov like the old days. And in an accesible loft it does NOT need MF terminals, so a case of someone not understanding the rules?
What sort of a moron posts a picture like that ?....and is so delusional that they think it is a good job??
could have done a much better job using one of the new Maxi Wagoboxes
how long until we get another ......"and to my horror inside the red fuse carrier was a lump of copper tube"?
i would email them about the 'pie dish' but I really cannot be bothered and I doubt it would make any difference. At least he did not get a prize for his
When I saw the Hagers set out like this I assumed they were to be hidden behind a wall forever
Mike Joseph ............... why did you use MF boxes?
Some poor customer has been ripped off paying for loads of MF junction boxes when a far cheaper, (and neater), solution could have been achieved.
Bending radius may be an issue due to orientation of cable
just noticed it appears  there is a twin and a flex dribbling out of the bottom ( of each box)
assuming twin for switch...why use a flex for the lights ?....this is assuming it is adequately supported and clipped since it is a flex. But since it was stated that access was a pain due to the half wall I am hazarding a guess at the 'throw,drape,fish' method
just saying
