ISSWWW
Which Earth Leakage Clamp
Which earth leakage clamp
  1. 1. Which earth leakage clamp
    • Megger DCM300E
      2
    • DiLOG DL6507
      16
    • Kewtech Kew2432
      2
    • Chauvin Arnoux F62
    • Fluke 360
      2
    • Amprobe DCG-1000A
      2
ISSWWW
As a result of this thread i am running a poll to see which Earth Leakage Clamp would be the best to try and get a special TEF deal on.
Your imput would be most appreciated,
All but the Chauvin Arnoux can be found on the web site at the bottom of this thread.
Edited by megger mark
missed something
Share this post
Link to post
Sidewinder
Will need to look at the specs Mark, definitely interested though.
What's your timescale?
Share this post
Link to post
Manator
I voted for the one I use rather than the one I want :)
That dilog looks great value for money my only real concern would be the size of the jaws.
Share this post
Link to post
Sidewinder
Now see Manator, I'm a Fluke guy, was brought up on them (& the AVO8!).
I have 5 Fluke meters of different types already!
However, IF MM had not brought this up I would have gone for a used Robin, which comes highly recommended from a reliable source, or, the Fluke.
Now I'm in a quandry!
Share this post
Link to post
kme
Now I`ve just looked at all the options; and I think that the higher priced options will be more suited to "niche markets", for their individual pros and cons; each unit can do what we would buy such a unit to do. If cost wasn`t an issue, my choice would be different; but taking everything I just read into account, I`ve voted for the Di-log, as it seems to offer the necessary capabilities at a reasonable price.
KME
Share this post
Link to post
Manator
I have to agree KME I was surprised at the low price, I need a new one and was just going to get a new fluke but and this is a big but, if that dilog does what it says on the tin for under
Share this post
Link to post
Sidewinder
KME,
Spill the beans, which one if cost was not such an issue?...
Share this post
Link to post
m4tty
I voted Di-Log as its looks quite basic and cheapness
Share this post
Link to post
PC Electrics
I voted Di-Log too. There's no way I can justify spending some of those amounts on a meter that will be used occasionally. The DiLog looks like it could be a valuable aid in fault finding at a very reasonable price. If I were engaged in fault finding on a more regular basis then I dare say my answer would be different, but I'm not.
Share this post
Link to post
Manator
I do some PIR work on large installs were it is often a limitation to power down to IR test, these meters are invaluable as an indication, faults can be localised by methodically testing along the cables to find any problem, I can also see how they can help to identify faulty appliances by showing lower imbalances than that of other type of meters, once you use them the more often you find you actually do use them.
Share this post
Link to post
kme
KME,
More than likely, the Fluke; though the Chauvin isn`t too slouchy on spec. The Amprobe seems like a clever piece of kit; but I wouldn`t use / need most of the functionality, TBH - back to my comment about "niches".
KME
Share this post
Link to post
Larnacaman
Well i also went with the DiLOG job. Basically because this is the bit of kit that will suit the needs of most of the electricians here. The others may be better in many ways, ...but not 200+ GB Pounds better. They may suit some that have niche areas of work as others have mentioned, but that's not what this poll is about.
The DiLOG DL6507 seems to be a good all round piece of kit that's under a 100 quid, and that's all that's required, the fancy bits on the other units aren't!!
Share this post
Link to post
ISSWWW
As soon as i feel the poll has run its course i will get a qty deal on the winner and maybe one other, thanks for all the comments and votes so far, already looks interesting.:worship
puncuation
Share this post
Link to post
Canoeboy
Voted for the Di-Log, at that price its one you cannot afford to buy and use
Have the fluke myself though
Share this post
Link to post
ISSWWW
Thanks for this mate, also thank you very much for the http://isswww.co.uk/ reference in your signature, I'm sure you know how helpfull this is:Salute:worship:Applaud
Share this post
Link to post
professional
I bought a Dilog (off megger mark) - incredibly useful bit of kit!
Doing an industrial PIR at the moment - usual case, neutrals not marked up or in any order ........ identified them with this bit of kit.
Share this post
Link to post
Rob69
Hi Megger Mark,
what sort of deal can you offer for the DILOG 6507 Clamp meter ???
cheers rob
Share this post
Link to post
Sidewinder
OK,
It's the Di-log or the Amprobe AC50A for me which Mark does not have on the poll, so I have gone for the DiLog, however, the AC50A offers an auto max capture, that could be REALLY useful for fault finding!
Mark has this on his site for
Share this post
Link to post
Sidewinder
I have finally managed to upload the spec comparison file to the Miscellaneous downloads area thanks to Admin.
Hope it is useful.
Share this post
Link to post
m4tty
Hi Megger Mark,
cheers rob
+1 :)
Share this post
Link to post
Canoeboy
+1 :)
+2
Share this post
Link to post
Sidewinder
Canoe, have a look at the Amprobe AC50A
Share this post
Link to post
kme
I just did..............
Mmmmmmm ( but Mrs. would take some convincing, with the new bus `n all............)
Tempting
Share this post
Link to post
ISSWWW
I really wish i knew how to do Multi Quote replies :(
In answer to questions above:
Sidewinder, I could do a special price on the AC50A and will post it soon, also can i say a special thanks for uploading the comparison chart. :Salute
Canoeboy and M4tty and everyone interested I have got a price sorted with Dilog but forgot to bring it home with me so i will put the price up on Monday, I can tell you it will be good even if i say so myself :tongue in cheek
KME you know you can't resist a bargain ;\
Share this post
Link to post
Sidewinder
Scoobs (black star in bottom lhs) accepted as thanks!!! ;):tongue in cheek:^O
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
