Hi Paul,
Here is a piccy of the armature of the thing when i first took it to bits. As you can see, it is fitted with a rather sturdy aluminum fan. Some numpty has given this a rough time and it has a fair bit, cannot remember exactly, but i suppose about 50 thou runout, plus i suspect that a balance weight might have come off, as one of the pins used to locate them is missing.
If you look closely at the armature itself, you can see that the fins have seen better days, and there is a balance weight pin missing off there too....
http://s1178.photobucket.com/user/resistance87/media/a.jpg.html
If you look at this photo when i was reassembling the thing, you can see the battered looking fins a bit better..
http://s1178.photobucket.com/user/resistance87/media/b.jpg.html
Problem was, when i ran the motor on its own, the bearings made a horrid noise. I replaced them, and it was exactly the same.....
It is not an electrical problem [so far as i know] because if you start the motor and then shut the power off, often the noise from the rear bearing continues for quite a while as it spins down, and if you rest your hand on the motor, as it slows, you can feel that as it slows through a certain speed range it will vibrate quite badly, and then smooth out as it slows some more.
I took the fan off and reassembled it, but it made no difference really. I have been messing with the thing for a few years, but i suppose i will have to take it to bits when i get round to it and get it balanced, cannot see i can do much else.
I have not had a proper measure yet, but i wonder if the motor is a weird size, as when i look at the flange size for a c160m motor, it is about 350mm diameter. I have not measured mine properly, but it is more like 400mm.
All the windings look ok, and it is nice and clean inside, and it checks out ok when i mess about with a meter, so if i could sort the balance, i think it would be ok.
I have no idea where the best place to take the thing would be though, so long as it was not mega miles, i would take it to bits when i got time and hopefully, they could balance it while i waited, i could always sweep the factory floor or something. Scared they would balance it and the postman bash it about again.....
john...
