DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Ac Adapter Compatibility
nimatahriri
Hi People,
Could anybody please dumb it down for me without too much details if I could use an AC adapter with Input : 100—240V ~1.5A  (not 2.5A) 50—60Hz as a replacement for my original AC adapter which was an Input : 100—240V ~2.5A 50—60Hz?
The device in question is a tennis ball machine.
Muchly appreciated.
Link to comment
All that matters with the input is the voltage and frequency range so that is okay.
BUT make sure the OUTPUT voltage and current is correct (and whether it's ac or dc) as that's just as important to get right.
Chances are, because the replacement adapter has a lower input rating so it will probably also have a lower output rating as well.
Link to comment
Many thanks.
I checked the spec on the original one which is:
Output: 12V==10A
The new one is pretty similar:
Input : 100—240V ~1.5A 50—60Hz
Output: 12V==10A
Almost identical, except for the input Amp which is 1.5A instead of the original 2.5A.
The machine company is quite sensitive with unapproved accessories and could cancel my warranty if things go south :)
Sadly, I'm clueless about electricals and just trying to avoid further problems.
Link to comment
That looks like it will do the job okay. Be especially careful that the polarity is correct, that is VERY important.
Link to comment
Yes, I managed to get the polarity info from the manufacturer. I have to modify the output cable end since the machine uses an XLR plug. So hopefully, I won't blow the thing :)
Many thanks again.
Link to comment
Archived
  • Create New...
