DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Vent Tiles
Barx
What's the norm when looking at a domestic property that has vent tiles in the roof. You ge the arc ones and the flat ones.
Here is a sample of flat one.  https://dl.dropboxusercontent.com/u/53092305/100_4384.JPG
Roofer has told me that it is OK to panel over them as the air still flows under the panels, I can see his point but thought I would check
Link to comment
Nobody got a view on this?
Link to comment
i would put the panels on top. its not as if youre going to seal all the gaps & sides so there is no air flow
Link to comment
I know nothing of this but.....if the vents are low level i would have thought they were for air input as hot air rising will draw air in from lower down........OR is it for hot air falling?....seriously i do not have a scooby
In either cas I would think any restriction to air flow could be an issue. Air will still flow under the panels but surely it will,be reduced as it is not now in 'open air'
Blocking could be a problem......birds nests, flying carrier bags etc
Just saying
Link to comment
hehe, one for and one against. That clears that one up then. I wouldn't even know where to get a deffinative answer. Guess I could try scam provider, see what they say.
Cheers
Link to comment
Bearing in mind that I do not know what I am talking about.......
Link to comment
and you think I do?!
Link to comment
IMHO I'd phone your LABC to see what they have to say
Link to comment
Irrespective of what you do, the vents are probably more likely to be obstructed by junk that the homeowner sticks in their loft than anything you fit externally.
Link to comment
Why didn't I think of that?
True that
Link to comment
Wouldn't the vent tiles be venting the void between the sarking/under felt and the tiles? Or am I missing the point
Link to comment
The vent tiles could be for a multitude of things. Extract fans, soil pipe venting, air flow etc, so best port of call would be as Noz says, then post answer on here for knowledge of others. :)
Link to comment
Ah, thanks for that. I wasn't looking at the broader picture
Link to comment
I was at a property last week where 2 of the 4 vent tiles were extractor fans, the other 2 were directly vented to the loft,
as said,
LABC is probably the best option, after all, they are the ones that can, and do, make you remove the install, we had one a while back, conservation area, that was something like 50mm higher than the velux windows and the original installer was told it had to be removed, we had to go and strip it off, use different mounting system to get it to height.
Link to comment
Well I rang Leeds LABC last week and they said to email the enquiry. I did this the same day, got an email back stating that it would be passed to the relevant person and a reply would come from there..............................
7 Days later, no such reply. Still don't know what to do.....
Going to but them tomorrow I think.
Link to comment
Why not VENT your spleen on them?
Just saying
Link to comment
plenty of air movement under panels, only thing to watch for is poo pipes - ammonia etc etc, and they can stink whilst you are working...
Link to comment
GD went a few months ago. I can understand the big energy companies not wanting to shell out for property improvements, it always did seem a bit odd.
Link to comment
Just a follow up, I pestered LABC and they got back to me. the official word is, as long as the panels allow air flow underneith and do not block the vent, they can't see it being an issue.
Going to save that email and panel away ;)
Link to comment
Archived
  • Create New...
