Power at one breaker, not the other and no tripped breakers.
Joenicholson1996
May 8, 2017
3
Newcastle
Not so quick question for anyone willing to help me.
September last year I ran a 6mm 3 core swa from my uncles house up to his summer house as the main supply. I added another small db (like a garage DB) in the house under the board and ran a cable from the live side of the main household breaker to the new db. This then ran through a main RCD earth leakage breaker to a 40Amp single pole breaker up to the summer house. There is nothing up there other than lights and a few sockets for a computer/heater and such like. I used glands and earth tags, putting an m6 but and bolt on the tag with a crimped earth to the main earth bar to earth the steel wired armour itself. Everything worked fine up until this month. I left my him to run the cable in the trees telling him to use cable cleats, of course he used aluminium fixings instead and I hadn't seen this until I went up to find out why it all stopped working. Basically I had 230 volts on the feed out from the breaker in the new house db, and I had nothing at the top of the garden indicating there was a damage in the cable, but no breaker had tripped. Considering how I used the earth tags to earth the steel armour as well as a cable in the 3 core swa, how could this possibly not trip the breaker?
Any help on this would be brilliant sorry for the life story but it means you know all the facts.
Would also like to add that I went up to sort it out assuming it was a damaged cable talking a joining kit but before I did that I changed all the glands and remade the cable ends etc and everything is working again 🤔 Any help is appreciated
cheers
I'd be looking at a missed cage on the busbar as a first stop,
There was 240 volts across the cable going out to summer house, but nothing across the cable at the summer house (until I remade all connections and both ends) could you explain what you mean please
When tightening breakers onto a busbar it is very easy to get the "finger" on the busbar on the wrong side of the clamp, the screw tightens up but doesn't grip on the bar. You can get power going through it but at some point it loses contact, possibly due to vibration or some other cause, this is one of the reasons why consumer units have recently began to "spontaneously combust", basically people thinking they've tightened everything when they haven't.
Thanks @phil d and @steptoe, will make sure this is secured properly. Don't want my uncles house burning down!
stick in an LFB approved  box and its guaranteed* not to burn down
*  its already been proven that an LFB approved metal CU cant contain a fire...
But wasn't that an old metalclad board, not a new LFB approved amendment 3 board?
LFB requirements is simply not readily flammable or something like that, basically made from ferrous material. id say an old metal DB fits that description, so its an LFB approved board. and it didnt contain a fire due to loose connection which is what they wanted to do
would be easier to make the board a bit bigger and stick a fire extinguisher in there
No guys you are wrong wrt Amd3 boards.
The requirement from "LFB" was to remove a source of fuel for any fire, not to contain anything.
The issue was the boards catching fire because they were made of flammable material.
We'll not go into why.
Thus the requirement for being made of non-combustible material, nothing more.
Oh, are we meant to be fitting metal MCBs now then,?
Surely the 'old' CUs were made from the same material as MCBs, ? :C
