DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Keith Williams
Dno authorisation
Keith Williams
I resigned from my job with Scottish Power last year,I was being investigated for gross misconduct. Is Scottish Power within their rights to stop me from being authorised to work for an ICP?
Share this post
Link to post
Sharpend
Who or what is icp?
Share this post
Link to post
misssweden
Independent Connection Provider
I think they can refuse your authorisation.
Share this post
Link to post
binky
 it sounds like you had 2 jobs on the go, in which case it is normal to inform your main employer of the secondary employer, especially if there is a potential conflict of interests.
Share this post
Link to post
ProDave
What exactly was the gross misconduct accusation?  Just the fact you were doing 2 jobs? or were doing something very wrong in the job with the DNO?
Share this post
Link to post
Andy™
its their network, id expect they can stop you working on it
Share this post
Link to post
Tony S
Without knowing the details of the investigation it’s hard to say if SP are within their rights. But as has been said “it’s their system”.
Share this post
Link to post
Evans Electric
I've never heard of an "Independent Connection Provider "  .
What is it ?   A company other than the area DNO who can work on the network   ?:C
Share this post
Link to post
Andy™
yep
Share this post
Link to post
Tony S
The DNO’s will rob you blind for a connection for either MV or LV. An ICP will run cables, etc to a DNO line from your installation for far less outlay. Then it’s up to the DNO to make the final connection so long as it meets their standards, this may be what the OP is falling foul of.
Share this post
Link to post
Evans Electric
So my £ 870  odd quids  ... 2 mtrs of cable  and   dig yer own trench  could have had another quote  . ???    Who are these people ?
Share this post
Link to post
ProDave
It's called "contestable work"
When I was getting the quote for a new supply to my house, one if the things in the quote was dig a connection pit in the grass verge on the other side of the road. The quote was something like £2K and that was already with me digging the trench on my own land.
As it worked out, I got the water connection first so Scottish Water made the road crossing.  While that was open I dropped in a length of duct for the electricity, and then dug my own connection pit the other side of the road.  So all SSE had to do was pull a cable through the duct into the meter box and make the connection in the pit I had dug.  That saved almost £1K from the connection cost.
Share this post
Link to post
Blue Duck
Bit close to the gas pipe;  isn't it?
:P
Share this post
Link to post
Evans Electric
:P
No choice  Ducky ,  that shape just to the right of the joint is also gas  which tees off into my house and next door ( exposed)   Thats next door's path , one cable feeds both houses.
Share this post
Link to post
Evans Electric
That was the daft thing on this ,  I needed my own fuse for the sub main   ( More than 3 mtrs  etc)   they  have to finish at a sealable isolator  , so two isolators  rammed in there . 5ad504061eb22_Photo0484(2).thumb.jpg.920a47387ca70f938ab7ba62703a37b0.jpg
Share this post
Link to post
Blue Duck
NOTICE TO ELECTRICIANS
This is our box and you need to fit more than one isolator but we need all this space for the meter so you better do it neat like.
Share this post
Link to post
Tony S
Where is the OP?
Share this post
Link to post
Sharpend
17 minutes ago, Tony S said:
Where is the OP?
At a disciplinary :C
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
