Location of FCU for Shower Pump
Hylthom
Apr 4, 2018
13
London
Hello guys
At first, I was locating the FCU for the Shower Pump outside the bathroom due to the environment.
On reflection, I am now feel I am able to locate it in the bathroom cupboard as it will be more than 600mm beyond the requirement of the Regs.
Please see the sketch I have attached.
Thank you.
If the cupboard is dry with no signs of moisture ingress/damage then I don't see a problem with it. I'm guessing it does have a door on it?
Many, many thanks, gents.
It does have a door and as it backs onto a party wall, dry.
Thank you.
depends on the bath panel, but clearly not as accessible as in a cupboard
Still disagree ................. unless there is a cupboard under the bath .........................................
put it this way ................... would you be expecting a client to get a screw driver out to remove a bath panel to isolate a shower ? I certainly woundn't
