B_I_L_L_Y
- May 14, 2018
- 3
- 0
I have recently had my garden fully wired (radial system ... whatever that means) in each corner by a profession electrician. I have been informed that I can run electric heaters, kettle, etc. with no issue and it runs from the consumer unit in my garage which I think is connected to a 65 amp RCD fuse and he said if I wanted to run power to my new shed then I can merely spur off of one of the double sockets to a separate fused switch.
Ok so what I want to do is be able to move my shed in and out to maintain it every year so was thinking of using a one of those IP67 adapters like you see when connecting caravans to cars, so having a fixed socket on the fence and have a trailing flex from the shed. The this trailing flex I was going to attach to a new smaller consumer unit in the shed (x1 for lighting and x1 for plugs) ... does this sound ok?
Cheers for any advice?
