Overloaded cable, or not ?
Feb 14, 2008
7,470
21
Cloud Cuckoo Land
Whilst retro fitting a rcbo i spotted this cable. Its feeding a kitchen ring but only a dish washer and occasional sockets.
The ring tested out fine, low value  end to ends etc.  Only 1 cable has overheated, i recon it was loose or even had missed the cage in the breaker. Whats everyone elses view.
Also, the breaker had thermal damage so that was swapped out.
Right.....
have a look at this blow up
the OK cable is bent over and has the end running N-S
tye melted cable has the end running 'flat'. I.e. E-W
if the cage is slightly curved then the ok cable will have tightened and the melted one will be loose
of,course this would NEVER have happened if a torque driver had been used 🤔😂
Perfect demonstration of why you should never double back the cable if there is more than one cable in the connector.  Straight cut cable ends would have avoided the problem.
Some MCBs  seem to be notorious for NOT catching all the cores in the box terminal ,  Crabtree  I think , is one of them .        Three 2.5s  specially vulnerable ...one is always loose until you've checked them 500 times .
I think, M'lud  that my learned colleague  for the prosecution is correct in his summing up .
Right.....
Well spotted. I took that pic holding the camera over my head as the board was near the ceiling and my steps wern't tall enough
probably been like that for years and now working fine, not sure I would leave it though - last one in and all that...
I've always had a theroy old electrics have welded the contacts together, I find old houses tend to test-out better than newer houses, but that might be something to do with quality slipping.
I think ,  as we've said before ,  a few basics seem to be lacking these days .
A couple of basic things with consumer units .     ( For  newbies to the trade )
Fix to a flat surface or they'll distort and you struggle to get the cover on .
Double check those "hard a iron"  meter tails in the box terminals  after bending & twisting them.
Count off the bus bar terminal screws  to be tightened & make sure all the "fingers" are in the boxes.
Make sure you tighten up   ALL  the terminals  with a (+) (-)  screwdriver .
As said above ....give 'em a tug when finished  specially 2.5 solid cores .
And a personal  idiosyncrasy .....    some boards have bare bus bars ...insulate them with some tape .
Also, Wylex for one say to use a P2 driver for all terminals
I  mean those ones ...the name of which always escapes me  .... Modulo   :C     half Phillips -half normal   .. I call them mad drivers .
All the ones I buy  have snapped off   ...just one  left  seems to be tempered properly .     Phillips  / Pozi   usually work as well TBH.
I,connected a cooker up for a mate a few months ago...........it needed 4 different screwdrivers!!!!!!!!!! WTAF is going on
flip,off cable cover.....flathead
cable clamp................torx
L-N...............................6mm hex
earth.............................5mm Hex
luckily all are in my WIHA interchangeable set but WTAF!
