Traineeboy
- Apr 22, 2020
- 201
- 17
Can I just double check that the only test you need to Null your test leads on is the continuity test ? So you don’t have to null leads on insulation resistance ?
Think it through logically. Say your leads have a resistance of 1 ohm.
If doing continuity, perhaps the circuit may be 4 ohms, so an error of 1 ohm is significant. So set the instrument to cancel out, (null), the lead's resistance.
Now, consider doing insulation. Let's say you are looking to measure greater than 4 Mohm, (four million). Ask yourself if that 1 ohm test lead resistance is relevant.
I have a Kewtech KT63..... the frigging thing needs to be nulled all the time.. not because the leads are fubared,,,, if it goes into power saving mode the null is wiped unlike my old Megger 1502 which stored the null
OP - if you find you have to null your leads onsite regularly then its probably time to buy a new set of leads - I find mine last about 12 months - but I do a lot of fault finding so my MFT is used a lot
