DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Correct cu for tt system????
meady
Question
6 answers to this question
Meady why not just install a CU with a main switch and RCBO's? saves messing about with multiple RCD's etc.
AndyGuiness Drink
Link to comment
I did think of that but it would have worked out more expensive for the customer, she can't afford much so I said I'll get a good make cu but try to keep the cost as low as I can. The rcbo's would cost in the region of
Link to comment
The only thin to point out with this CU is that it only has 2 nutral bars so no unprotected circuit
Link to comment
All circuits need RCD on TT AFAIK
Link to comment
I always point out that single circuits with Rcbo's is better than dual Rcd's if you have a fault as it is easier to find and will never put cooker circuit through Rcd through experience of nuisance tripping. It may cost a little more but remeber its you that will be called when things go wrong.
Batty
Link to comment
Archived
  • Create New...
