DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
neutal link or switched
kye
Question
hi,im fitting a 125a 3 phase + n 12 way mem dist board.with a mix of single pole mcb and some triple pole mcb the main isolator switches the 3 phases and the neutral is a solid link.my question is when would you use a 4 pole main switch to complete isolate the 3 phases and the neutral as im starting to wonder if i should use a 3 or 4 pole main switch disconnector hope that makes sense !
Link to comment
3 answers to this question
If it is TT makes it differcult to comply with 17th as you would probably need Rcd as main switch but cannot use one Rcd as breaks regs bet the writers of regs forgot about that one.
Batty
Link to comment
all poles on TT should be disconnected
Link to comment
Archived
  • Create New...
