flicking light
Andy™
©Resident Geordie™
Jan 1, 2009
30,531
1,220
S. Tyneside
customer has a HF fluorescent light in the same room as a laser. when the laser is used, the light flickers.
im guessing its the laser interfering with the electronics in the fitting, so do you think changing to switch start would solve the problem? or any other solutions?
I can only guess that it will . Does a laser also transmit RF ? I don't know. An ordinary fluoro has the old wire wound choke while the HF fitting is pure electronics, go for it !!
