DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Todays domestic periodic.
M107
Sorry peeps I forgot my camera so no pics as yet......but I'm bound to get the remedial work so pics will follow in the future.
Anyway the list of faults on the newly wired extension & cu change (to a volex split load :( ), apparently the sparks they used forgot to renew his part P credentials & has since dropped off the face of the planet.
Cu cover not fitting properly leaving a gap between rear case & cover (over crowding with cables)
Multiple surface pattresses with ko's missing
Non IP rated lighting in showers
DL's in bathroom going rusty not fit for zones
Unterminated live conductor hanging from external wall (wrapped in selotape)
No MEB to water
New ring final no rcd
New cooker circuit + socket on ccu no rcd
Class 1 light fitting not earthed in bedroom (no cpc at fitting)
No grommets on any back boxes.
No cpc continuity to any DL light fittings in 2x bedrooms
master bedroom lighting reversed polarity N & L (neuts are switched)
No cpc to half kitchen DL's
No isolation for kitchen extractor hood
CU busbars missing
KO's missing on underside of cu access to live busbar
All this from I'm sad to say a supposedly time served NICEIC registered electrician.
Problem is in a round about way I know the bloke that did the work....so do I report to the powers that be.......... b***** right I do first thing in the morning.
Link to comment
Think you have to report it.
If it was one silly mistake it's one thing (we can all have bad days) but with that catalogue of errors someone could be killed.
Link to comment
I do wish M107 would stop going round to all my customers spying on my work!!!!:OBlushing:^O:^O:^O:^O
:coatGuiness Drink
Link to comment
What does NICEIC mean? I forgot.
Oh yes, now I remember!
National Institution of Cretins Electrically and Individually Challenged!
X( play fair, im niceic registered, and always do good quality work X( any problems, and i go back and sort, so dont tar every electrician wioth the same brush thankyou ! X(X(X(
Link to comment
:coatGuiness Drink
X( banned ]:):D
admin can you please remove specs, with shoddy workmanship like that, hes letting the side down rapidly ]:)]:)]:)X(X(:o:O:|:_|:_|:(:(:^O
Link to comment
Same here Badge.
Well I made a couple of calls & property owner has now taken up the mantle & is liaising with NICEIC & has put a call into LBC.....
Link to comment
X( banned ]:):D
I'd agree with that proposal.
Link to comment
Same here Badge.
Lets hope there is actual some appropriate action taken.
Link to comment
dont report him. go and buy him a drink and thank him for putting the work your way
and while your having your drink with him ask him were else he has been working. you wont need to worry about the recession LOLApplaud Smiley
Link to comment
Archived
  • Create New...
