Hi All
Hope all are well and keeping safe.
It is that time of year and after turning my storage heater on it was still cold in the morning. It is a Dimplex CSLX18N on economy 7. The other heater on eco7 works, as does the convection heater on the main one. The fuse box and the fuse in the plug are ok. As per the orginal thread I checked the resistance on the ceramic termial blocks below the elements and get 31.5 Ohms on all of them. First question, is that correct for three elements or does it indicate not all of them are working? Am fairly sure, on past experience, that if one has failed the heater should continue to work with reduced storage.
I noticed that a plastic cover on one of the connections looked burnt and after minimal prodding it disintegrated. There is what appears to be a thermal switch but it does not click when depressed. It sounds like I can't post images until I have made more effort, so have shared some images on google (my phone apparently doesn't like macro shots very much):
https://drive.google.com/drive/folders/1DQiiHVLmqajfNXuWqhI3QddeO8P7paHD?usp=sharing
Is there anyway I can test this (if it's obviously not dead already) and is it something a non-electrician like myself can replace or should I be getting someone in at this point?
Thanks,
Ian.
Thanks,
Ian.
