DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
bathroom downlights
derek13
Question
hi people,
could do with some help to put u in the picture am lookin to install 5 downlights in bathroom but am unsure about the regs ?. i now believe that any work now done in the bathroom will need rcd protection? would not really be a problem but the fuseboard is an old one with re-wireable fuses so that i take it will be a no-go?, which leads me to ask is there a way around this and can anybody help as im unsure with the 17th edition etc so thought this would be the perfect place to ask:)
thanks for any replies greatly appreciated Guiness DrinkGuiness Drink
Link to comment
14 answers to this question
Evans Electric
Put the bathroom light feed through an RCD spur unit . All bathroom electrics are supposed to be notified to Electric Police and carried out by a certifiable sparks .
Deke
Link to comment
NozSpark
They should also be IP55 (sealed) so that moisture cannot get into the ceiling void or loft space.
Link to comment
any idea of cost of the units guys? also will it just be a case taking original light feed into the rcd spur then out to lights keeping same switch wire in place?
thanks very much for taking time to reply
Link to comment
NozSpark
Personally I'd take the loop in / out to the RCD FS and then got to the switch & lights.
They cost about
Link to comment
Evans Electric
Cost about
Link to comment
what silicon do u use to seal (flum seal)?
Link to comment
NozSpark
You don't need any sealant... the fittings come with sealing rings
Link to comment
fitted some befor and they did not sit tight it said in the instructions to use a sutible silicon sealent if they are not tight to celing.
wont be useing them again
Link to comment
How many downlights? what wattage?
AndyGuiness Drink
Link to comment
3amp shouldnt be a problem then.
AndyGuiness Drink
Link to comment
Archived
  • Create New...
