DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
main bonding size
Lee321
Question
10mm
Link to comment
hmmm i'm under the impression its not that clear cut Apache
maybe so. I will be interested to see. Ok I'll ask what the earthing arrangement is?
Link to comment
Table 54.8 would disagree with that and support Patch. Neutral is 35mm or less, then 10mm. Check out BRB pg 134.
Link to comment
pme
Table 54.8 page 134, bottom part of reg 544.1.1
C.S.A. of supply neutral 35mm or less
minimum C.S.A. of main bond = 10mm:D
Link to comment
quote "buried earthing conductors must be atleast: 16mm copper if not protected against mechanical damage but protected against corrosion
Link to comment
when did we bury anything?
Link to comment
"EARTHING"
not
"BONDING"?;)
Link to comment
The Don's boys have to bury horses without heads all the time ;).
No they don't. Ever wondered what goes into to a hot dog and those fishshop 'sausages'?
Link to comment
Applaud SmileyApplaud SmileyROTFWL
Link to comment
So the important thing - I was right all along ;)
Link to comment
"EARTHING"
not
"BONDING"?;)
Well it is in note 3 of table 4.1 in OSG referring to bonds. Guess its if you need to get from one place to another and have to bury the cable (e.g. under a door step).
Link to comment
No I haven't for that very reason.
Link to comment
buried means either surely?
Link to comment
Archived
  • Create New...
